Колеги здравейте. Сканирахме Пасата на един приятел, който не пали.
Малко предистория. Дал е ток на друга кола, след което и той запалил малко трудно. Пробрал се в къщи без проблеми (около 80 км). Като спрял вече не запалил даже и с бутане или даване на ток. Заредил е акумулатора и пак неще.
Грешките са както следва :
VCDS Version: Release 11.11.3
Data version: 20120401
Auto-diagnostics Ayhan
Sunday,20,July,2014,14:18:39:32264
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 199560km/124000miles
Address 01: Engine Labels: 058-907-55x-AEB2.lbl
Part No: 8D0 907 558 B
Component: 1,8L R4/5V MOTR HS D03
Coding: 04001
Shop #: WSC 05314
VCID: 30650E19F038729
4 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-00 - Voltage too Low
17916 - Idle Control Sys
P1508 - 35-10 - Upper Regulation Limit Reached - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
00561 - Mixture Adaptation
12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB980A1DA2CB49
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 A
Component: CLIMATRONIC S 9.0
Coding: 02000
Shop #: WSC 05314
VCID: 1F47FDA59DA6FD1
5 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00538 - Reference Voltage
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01206 - Signal for Duration of Ignition Off Time
00281 - Vehicle Speed Sensor (G68)
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 607 A
Component: AIRBAG VW3 S V04
Coding: 00065
Shop #: WSC 05311
VCID: 2B5F1975D91E111
1 Fault Found:
Address 17: Instruments Labels: 3B0-919-xxx-17.lbl
Part No: 3B0 919 861 B
Component: KOMBI+WEGFAHRS. MM4 V12
Coding: 04142
Shop #: WSC 00000
VCID: 2953E37DD3E2031
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0W2041089
Ident.-Nr. Wegfahrs.:VWZ5Z0W2041089
1 Fault Found:
00667 - Ambient Temperature Signal
29-00 - Short to Ground
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 08 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 04926
VCID: 4C9D7AE97CD0369
Subsystem 1 - Part No: 1J1959801B
Component: 08 Tõrsteuerger. FS0022F
Subsystem 2 - Part No: 1J1959802C
Component: 08 Tõrsteuerger. BF0022r
Subsystem 3 - Part No: 1J4959811B
Component: 08 Tõrsteuerger. HL0022r
Subsystem 4 - Part No: 1J4959812B
Component: 08 Tõrsteuerger. HR0022r
13 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01334 - Door Control Module; Rear Right (J389)
49-10 - No Communications - Intermittent
01333 - Door Control Module; Rear Left (J388)
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00930 - Locking Module for Central Locking; Rear Left (F222)
End ---------------------------------------------------------------------
и след като ги изтрихме, останаха само тези:
Sunday,20,July,2014,14:37:25:32264
Coding: 04001
Shop #: WSC 05314
Readiness: N/A
Shop #: BB 24548
Coding: 02000
Shop #: WSC 05314
Coding: 00065
Shop #: WSC 05311
Coding: 04142
Shop #: WSC 00000
Coding: 04097
Shop #: WSC 04926
Component: Fahr. antwortet nicht
Component: 08 Tõrsteuerger. BF0022B
13 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Според мен симптомите са на бензинова помпа, щото колата пали на бензин. Прибрал се е без проблеми щото карал на газ. При даване на контакт не се чува никакъв звук откъм помпата.
Въпроса е - защо по дяволите няма никаква грешка свързана с помпата?
Има ли начин заради толкова много грешки в комфорт системата да не пали?
Passat B5 1.8 бензин газ - не пали
- Регистриран на: Съб 20 окт 2012 13:11
- Автомобил: Dacia Logan
- Двигател: 1.4 2007
- Местоположение: Burgas
Последна промяна от ivostefanov на Пон 21 юли 2014 18:20, променено общо 1 път.
Причина: Придържай се към темата шаблон по стриктно.
- KGL
- Регистриран на: Вто 22 ное 2005 13:59
- Автомобил: Passat B8 Alltr BMT 176kW TDI
- Двигател: CUAA 2016
Re: Passat B5 1.8 бензин газ - не пали
При подаване на контакт проверете помпата или и подай ток директно от акума., при мен беше същото. Смених помпата и сега съм ОК
Мерси колега, ще я дръпнат и без това до майстор. Щото помпата се пада под газовата бутилка и бая работа има и няма смисъл да се мъчиме сами. Защо няма грешки от помпата??? Помпите при VW нямат ли контролери?
Потребители, разглеждащи този форум: Няма регистрирани потребители и 145 госта
